Diy: Oem style full length roof rack
Freb_mc
So this is my first DIY, I hope it is understandable, and sorry for crappy cell phone pics. Anyway, I was tossing the idea around for a while and decided to finally go for it. I snagged an oem rack from a 97 limited in pick-n-pull.
Tools needed:
T25 Torx
Small flat head screwdriver
sharpie
DREMEL and cutoff wheel
cordless drill
set of high speed metal drill bits
Threaded nutsert tool
at least 6 inserts M6x1.0 I had extras just in case you mess one up
tube of silicone
grand total was less than $35, the rack cost $22 at pick n pull, inserts were $10, and silicone was left over on hand but is usually about $3
First step was to remove my end caps and take a measurement for how long. I wanted the "extensions" to be, 28 inches is what I settled on, any longer and the end caps wont sit quite flush.
[/URL]~original[/IMG]
Then get the new rails and cut them down to size
Install at least 2 cross bars to square up your new rails, I also popped up my sunroof a bit to make sure it was going to clear. (place your cross bars so as to not block any holes)
With it set into place tape it down so you don't have any movement, and mark the center of all your holes(6 total)
Helpful tip, start with a small pilot hole, then work up to your final size. Also mark the depth you need with tape on your drill bit, its a make shift depth gauge so you don't drill too far.
I drilled holes in my roof? What was I thinking?!?! too late now...
This is a threaded nutsert tool. Cheaper ones can be found for at DIY, but I have a buddy that works at a semi truck shop and he loaned it too me.
Line your holes with silicone before inserting your threaded nutsert. This helps seal everything up.
Installation is similar to a giant rivet.
1 down 5 to go
A full row installed
A bit more silicone on the threads of the bolts to seal it up, don't want any leaks in your roof.
Loosely install the new rack extensions, leave the bolts a bit loose till you have all of them started, then tighten everything down with the end caps in place on the front and it is done! Total time took about 2 hours, because I was taking my time measuring everything 3 or 4 times.
And Job Done! All that's left is to try to explain to your wife what you just did because "your truck looks the same, did you even do anything to it?"
can you grab a pic of how close this was to your sunroof. I measured it out on my 4runner and thought the rail would be laying on the sunroof seal instead of the roof. It looks great tho! I'd love to do it myself.
I actually have a piece of track ready to do this on mine as well. I want to be able to mount my roof box farther forward.
Nice How-To!
-M
I will try to grab a picture for you as soon as I can. The only contact I had when I put it into place was the rubber seal under the rails barely touched the rubber seal for the sunroof, I was going to trim it if needed but the sunroof operates just fine and it doesn't interfere. On a side note, I never realized the sunroof is wider at the back than the front.
Those turned out nice. What rims are those? Tried scoping your garage but didn't seem updated.
Thanks, I just put them on, from a 2005 SR5 sport. I bought them a member on here. Made the truck a lot newer over the old split 3 spoke style I had before.
[MENTION=108410]RockenAlex[/MENTION] Here is a couple pics, it sits very close but mine operates smoothly past it. You can see the little bit of rubber I was going to trim but didn't end up needing to.
Very tight, but looks good! Much appreciated man!
I don't know if this is a lost cause based on the date of the post, but if the OP or anyone else has done this mod, I have a few questions:
1. What size rivnuts are used?
2. Regarding the depth gauge for the holes drilled. I haven't taken off the headliner before, but did you check ahead of time to make sure there were no wires/drainage tubes below?
this has also been covered recently in a different thread. I will be doing this in about a month ( when I get back to where my 4runner is) I got all the parts at a wrecking yard. I was able to see a 4runner without the headliner on and looks like all will clear.
IF this thread link works, go near the last few and you will see this style mod, my questions etc
Inexpensive Full Length Roof Rack (Curt Rack)
Thank you. That is helpful. I was hoping someone had a pick of the holes from the inside, to see how close you get to doing some real damage when drilling them out.
matisgugle
