I've got a 96 4runner, limited 4x4 w/V6. The left rear oil seal was leaking, so I replaced just the oil seal about 6 mos ago, but it still leaked. So I figured I needed to replace the bearing. I took it into a shop and they pulled the bearing off and informed that there was a BIG gash in the axle, right where the axle seal fits. It appears someone had cut an axle seal off in the past with a torch or grinder and got carried away. Anyway, the shop says I need a new axle because any oil will leak through this gash (if you've taken these apart, the gash is just inboard of the slot for the bearing keeper).
So, I order a new axle kit from Napa (axle, bearing, axle seal, for $275.00). The axle shows up and it turns out it's different from the old one. Napa tells me that there are two different axles for the 4runner, a common one (the one Napa sold me) and an unusual one (the one I've got, that no one makes).
Has anyone ran into two different size axles, or is Napa just giving me the run around because they sent me the wrong axle?
Thanks for any help or ideas.
