Do I have the correct remote?
Hello all, I recently joined the 4Runner ranks with a ’02 SR5. I've learned a lot already from all I've read here. I've searched to see if I could answer my question myself, but no luck.
I’m wondering if I received the correct remote with the truck. I believe it has the RS3200+ installed, but the remote I have appears to be the one for the factory keyless. I may be simply misunderstanding something.
What I have is the 4-button remote, FCC# HYQ1512Y with no LED.
The reason for my question is that I want to set the remote to unlock all doors with one press, but the RS3200+ instructions don’t “take” – the truck acts like it isn’t “seeing” the remote.
When I use the RS3200+ instructions to reprogram the remote, the system doesn’t “take” it either; but when I use the factory keyless reprogram instructions it does “take”.
While I haven’t pulled panels to make sure the RS3200+ module is installed, the RS3200+ instructions seem to work up until it’s listening for a remote, I can set the passive-arming delay per the RS3200+ instructions, and it has the security thingy in the knockout to the left of the steering wheel which looks like the attached graphic.
Do I have the correct remote? If not, what’s the FCC ID I should look for and/or Toyota part number?
Thanks.
-- Lew
Thanks.
-- Lew
