do toyota oem radios have locking codes?
keakar
my 06 has the dredded #3 error code so im looking at a cd radio from ebay but a friend said all chevy oem radios have lock codes if its unplugged or loses power, is this true for toyota too?
if so how do i go about getting an oem replacement or should i just try to see if its possible to swap out just the cd portion of my existing radio from another oem radio
PS - if it matters i have the upgraded JBL sound system in mine and it says JBL on the radio
can you use any oem replacement radio
I’ve swapped the headunit in my 07 several times - 3 different Toyota units altogether and never needed to unlock any of them. FWIW, mine is a non-JBL.
I have an OEM 6-disc changer headunit, and a Scion Bluetooth touchscreen that I’m not using if you’re interested.
thanks, thats what i was hoping
i never even knew chevy did this, it seems very stupid even though i understand the idea was to reduce theft, but who would steal oem radios lol
i just bought an 04 chevy but it looks like im stuck with the crappy base radio unit or buy aftermarket for that one because im not going to a dealer to get a radio unlocked
hell now that i am thinking about it, i might just get another JBL toyota cd radio and put that in my chevy because i dont need touch screen with navigation and rear view camera and that seems to be all they sell today in aftermarkets lol
im sticking with the JBL version for my runner but do you know if that fits in a 04 chevy 1500 and what would you want for it shipped to 70068
Physically it may fit, but I’m certain the electrical fixtures would be different on a Chevy. You’d probably have better luck going aftermarket.
i think you misunderstood what i was saying
im talking about changing radios in a chevy truck and my 4runner at the same time, not from chevy to toyota or vise-versa
it just blew my mind finding out chevy radios need unlock codes and i thought maybe toyota might have that same setup so i came to ask about it, im very glad to learn 4r dont have that stupid lock stuff
in the 4runner i have a jbl unit im replacing with a regular standard brand oem radio. i assume its just plug and go but i expect that maybe it puts out less watts then the jbl
in my chevy truck i am swapping out a straight radio only to a cd radio
OEM Radio
Double check with whatever head unit you buy, just make sure it'll be compatible with JBL. I have a NON JBL head unit I replaced with a Toyota 86 / FRS. I just needed to buy adaptors but basically plug and play.
I have the OEM 6 CD changer if you're interested, I have a NON JBL system in the car and I don't know if they are compatible. You're welcome to have it for $45 including shipping or less depending on shipping. I'll weight the box when I get home, I'm not looking to make big bucks, don't mind helping out and my OEM head unit will just sit in the basement. message me if you're interested.
i have the jbl synthesis cd and the cd went out so i bought this one to replace it with 4th Gen Toyota 4runner CD Radio for sale online | eBay
are you saying i will need an adapter plug for that?
if it needs an adapter then can i just swap out the non jbl cd player section to put into my jbl unit?
I am guessing that it should be Plug and play - reference to the wires plug in to the head unit. BUT do research a bit about JBL. When researching what head unit I should replace mine with, I recall JBL people have some "road bumps" when they replaced head units. I don't know what difficulties as I do not have an JBL system.
But there should not be any codes on these toyota head units. just compatibility with JBL difficulties. Sorry I can't be more help.
I'm not sure but I don't think that unit is going to work with your JBL wiring since I think the JBL radio has to sent power to the amp and I don't think that unit is setup for that, whether the CD portion can be removed and installed in yours I don't know.
hmm, that sounds like bad news then, i might have to send it back and buy the jbl one but those ones are pricey. so much for saving a few dollars
The one you bought might work, only way to know is try it, if you do get another one just make sure you get one that is exactly like yours because the JBL stereos as well as the non-JBL changed a little bit during the 4th gen build period so the wiring connections could of also changed, look for the same model number that's on the face plate or at least at the connection on the back to make sure they match what you have now.
well i had time to pull it apart today
regular cd radio has 2 plugs but the jbl has 3 plugs and the big plug has extra pins and a different shape so its not even close
i managed to get my cd back out of it but after putting it back together its showing it has 6 cds in it but its empty and it wont try to eject any or reset the trays. i did see a video where if you apply 5 volts to the right pins it makes the trays reset but i dont have a 5 volt transformer or any idea what pins to apply juice to if i did so i say its pretty much beyond help.
im getting ready to sell it so let the new owner decide if they want to replace it with another jbl for around $50 on ebay or go aftermarket
Two years later, you still have a radio for sale?
bobdjr41
