Do you have an Engine Bloack heater plug?
bcdave
It is winter so...
Do the sr5's come with engine block heaters in colder climates? Where's the plug located?; I haven't looked too hard yet but didn't see one ...
Looked in the owners manual and cant find any reference to that, nor in the index. There's a couple of posts here, not clear if its standard install in colder areas.
and does your sr5 have insulation attached to the underside of the hood?
Happy holidays
Cheers bcd
yup
On the front right side above the fog, personally don't like that little cover and pins, and trying to plug in the dark at -35 makes it fun.:sad:
Right (passenger?) side; saw something with a yellow harness beside the rad low, outside, bottom, on the other side left (drivers); but didn't want to go pulling at wires yet ... pic?
Hood insulation??
Yellow wire harness = Airbag sensor wires. Might not want to mess with those.....
The block heater plug-connector is near the fog light (on the driver's side). You will need the Toyota proprietary cord to plug into the connector on the truck. And then, plug your regular extension cord into the Toyota cord.
ah ha, have to look there ... thanks.
No way dude, we get hit all the time with weather! I had to 4L it through a puddle at Target the other day.
puddle of water in the target parking lot? add-30 to the water and that's why you need a block heater; ie Montana in Feb; not needed on the coast.
The block heater core is for -30; 3 ft snow drift and blizzard so you can get going in the morning and not freeze for 1/2 an hour
Thanks for that info, I was curious if I should get one in my climate (Kansas City). Guess it is not necessary though, probably easier (maybe) to just make space in the garage for the 4R...
Id be more concerned about a tornado damaging your 4R or garage.
You definitely don't need one in Kansas, or anywhere south of Minnesota, really.
Jhunt
