Dobinsons IMS 2-3" Lift Details and Review
about the front IMS shocks for the 3rd gen, is there enough adjustment thread if in case you want to lower the ride height if in case one has a "longer-than-stock" length of coil springs?
Yes. The body is fully threaded but you shouldn't go lower than OEM coil seat height as your sway bar could make contact with the coilovers then.
Hi Mike,
Thank you for replying to my post. The issue that I have is the front coils + 1/4" top spacers are given more than 3.25" of lift and I would like to use the threads to lower the lift height to 2.75" by lowering the spring perch without removing the top plate.
The sway bar and end link are far from the shock body in the 3rd gen.
I Hate to be picky, but it's damping, not dampening. To dampen is to get slightly wet. To damp is to reduce.
I'm sorry, it's just a pet peeve of mine...
Pat☺
The alternative definition of "dampen" is to "make less strong or intense". The more you know...
