Drewfus_'13Limited
I'm not sure that I installed my front Dobinsons struts correctly.
When I received them, the top cushion/washer setup was not the same as what was on the strut I removed (X-REAS if that matters).
The Dobinsons had:
nut
washer
cushion
washer
cushion
washer
strut
The OE strut had:
nut
washer
cushion
washer
strut
I tried to get the Dobinsons in with all of the new hardware, but I couldn't get enough of the stud up through the mount to secure the nut, so I removed the extra cushion and washer so that the setup matched the OE parts.
I've finished the install and driven it. I don't notice any issues, but I'm thinking it's wrong.
Also, it's not siting as high in the front as I thought it would. These were supposed to raise the front by 0.85", but I didn't see any lift. The extra cushion/washer won't add up to a full 0.85", but it won't hurt.
What is the correct way here? Thanks
The Dobinsons had:
nut
washer
cushion
washer
cushion
washer
strut
The OE strut had:
nut
washer
cushion
washer
strut
