Does anyone have a good source to educate myself on lift/suspension parts?
minimalist
I have no idea what to look for in a lift kit, what each part does, etc. I've never worked on cars and know very little so I'm hoping to educate myself a bit before I decide on what lift I want and what my lift should consist of.
What year is your 4Runner? Typically each subforum on this site has a comprehensive list and info on lift kits for each generation.
If you want to lift a 4Runner, then you're already in the right place.
Your first step is to ask yourself three basic questions.
1. Exactly why do you want a lift?
2. How high would you prefer to go?
3. How much money do you want to spend?
Answers to these will start you down the right track. People can then narrow things down further from there.
I guess what I'm trying to figure out is what's the function of each part. For example, control arm kit, link arms, shocks with remote resovoir, etc.
And for questions asked 2015 4runner,non KDSS. Not even sure im going to be lifting this 4runner though. Really looking to just learn some stuff
Front suspension looks basically like this
The coil spring has a shock absorber in the middle. Often called struts because the body of the shock has structure importance for the coil spring. Also called coilovers. All that does is control the ride height and absorb bumps. The A shaped parts are called upper and lower control arms and these define the location of everything. They rotate up and down and keep the wheel mostly upright as that happens. When you lift above a certain point, control arms need to be modified or replace in order to allow more suspension travel because the factory parts have a set range of motion. The coil spring and the strut are the main items that control the amount of lift you get. A coil spring with more turns, or thicker wire diameter than stock will provide greater increase to compression, resulting in keeping the vehicle weight higher off the ground.
Rear suspension looks basically like this.
The coil springs perform the same function as the front, but the shock absorber is independent. The upper and lower links (control arms) in this case are basically straight rods connected to the axle housing at one end and the chassis at the other. These control arms keep the axle housing in place but allow vertical motion. The longer they are, the more range of motion you have, providing the springs and shock are also longer. Another item not show is the panhard bar and locates the axle housing left to right.
Thank you! This is exactly what I was looking for. If you know of places where I can continue to see things like this is greatly appreciate it
AndiGarage
