Has anybody found Toyota door edge guards for the 2010 TE? My dealers parts manager says there is no listing yet from the regional warehouse in Houston area.
I put the first chip in the back driver's side door edge this morning. Has anybody found Toyota door edge guards for the 2010 TE? My dealers parts manager says there is no listing yet from the regional warehouse in the Houston area. I want the Toyota ones to match the paint instead of going with an aftermarket black.
These are metal and factory painted.... now I just have to figure out exactly how to install them. They're molded to the door - but I can't figure out exactly what part of the edge of the door they go!
Anyone have the PDF of the instructions???
I installed these on my LTD. I was confused on how to install at first since they were slightly bent. Luckily the packaging is labeled left side and right side. All you need is a rubber mallet for installation. Start at the top and work your way down. Line the guard up with the door edge and lightly tap into place with the mallet. Do this down the entire edge of the door.
I've attached a pic of the position of mine. I started the top about 1.5" above the door handle
Hope this helps a little.
