Door Keyhole won't let key all the way in
ouki
I always use keyless entry to lock and unlock the car. Today the valet parking guy told me that he couldn't insert the key to the keyhole in the driver's door. I don't know what caused it, I could only insert the key half way so of course the key won't turn. Has someone had their door lock fixed? Any easy DIY tips? Who should I call to get it fixed? How much am I looking at?
I'm in a similar boat. Key won't turn in the door cylinder. My guess is, the cylinder is just corroded and the tumblers are stuck. Take it to a locksmith to have them overhauled, is probably the easiest option. Otherwise it's new/used stuff and all-new ignition keying.
I'll definitely try that option. What if there is some object stuck in the keyhole? What's the best way to get it out?
hmm...
I don't know how that would happen, or it at least seems highly unlikely. I guess it's possible one of the tumblers broke and lodged in there, but I digress.
If you have something stuck in it you could try "flushing" the lock with (wd40, carb cleaner, pb blaster) or something of the sort. Then let it dry and dust it with graphite to re-lube. (I don't like this idea very much-but i've done it and as far as I can tell I didn't do damage. It very well could exacerbate your problem though since you are going to flush and lubricants you may have)
I dont think that would be your issue though. I think you just have a tumbler sticking. If I were you I would:
1. Puff that lock cylinder real good with graphite
2.Will the key go in now? If no, jiggle, fanagle, take in-out and try to work the graphite in.
3.Still won't go in? Stick the key as far in as it will go, and get you a hammer. VERY CAREFULLY give the key a few taps and try some more jiggling. Try more graphite, too.
4. Still no go? Head to the locksmith or pull the interior door panel off and swap the lock cylinder with the passenger side?
I'm having a similar issue with the lock on my liftgate, so please share if you're able to resolve your issue.
Dry lube such as graphite mentioned above is all you need. My locks get seized up living near the beach. I get the sprayable graphite lube. Put the little red straw into the lock and spray, then put your key in and out a bunch while turning it. It will eventually go back to its normal self. :)
Mike Sargent
