lock actuator on limited
Hi all, I just replaced my drivers door actuator on my 12 limited. Not a bad job and all went well - takes about 40 mins.
Question though- all works as it should except touch door handle.
I tested all after finished but didnt think to test outside door handle for "touch" unlock.
Any suggestions?
Dave
Update: In case anyone comes back to this in the future looking for help.
I purchased from Actuatorplus on Ebay as was suggested in a post here. Lifetime warranty if you return your "core" actuator. Quick shipping and great product support.
I reached out to them via email regarding my "touch lock" issue and Lenny replied very quickly with a nice email detailing how the lock cylinder extension rod was likely not in the socket on the actuator and sent the following:
Thanks for contacting me. The issue you are detailing is a very common key rod alignment problem that can be corrected 99.99% of the time. The problem relates to Drivers Door actuator - the circular gear in the bottom corner of the actuator with the cross notches in it. There is a rod with a cross end coming from your door key system that needs to align and fit into this gear on the actuator. Your old actuator is rotated exactly to the position of your rod and fits in perfectly, the new actuator needs to be adjusted in place. If you are able I would like to try a quick troubleshooting method to see if we can get this corrected. Usually during installation I have to remove the 3 torx screws on the latch. Holding the actuator in one hand I insert the key into the lock and rotate back and forth a few times. When it seats you will hear a click. Other times I have to remove the connecting rod to get it to align properly.
Here is a good instructional video detailing swapping a door lock actuator.
At the 12:00 time mark the installer is having trouble connecting that rod so he has to pull the rod out and shows how to realign it.
How to Replace Front Door Lock Actuator 06-11 Toyota Camry - YouTube
This was exactly what my limited's touch lock issue was and once I realigned my rod with the socket all was working as it should. The unlock touch worked fine it was only the touch to lock that didnt work.
I highly recommend Actuatorplus on Ebay for this commonly failing part if you dont want to mess with rebuilding one yourself.
