TSP-Mike,
First thanks for the response. I am not sure I follow your thinking though. With the problem being the drivers side lock, what about the passenger side should I be looking for? or did you mean drivers side? Can you give a better description of what I am looking for once I get the door apart.
I'll try to descibe the issue again a little more clearly...
When using the drivers side lock with the key the lock will manually open or lock the drivers side door only, but does not open/lock the others electrically as it should. From inside, the drivers side switch will open or lock all doors. On the passenger side both the door lock and inside switch open and lock all doors as it should.
