Double deck/non-double difference in Cargo Liners?
Okie
What is the difference? Is one shorter than the other? I have a double decker - have not seen a 4 runner without it.
Also, who has the best price on a rear Husky Liner?
You can compare this one to yours with double decker, but I believe the difference is that the dd is not only shorter but the side wings are different as you have the plastic trays built in and the non-dd does not.
This is with the DD.
P3270078.jpg~original
IMG_0289.jpg~original
IMG_0290.jpg~original
IMG_0291.jpg~original
IMG_0292.jpg~original
The center where the shelf is located is raised. The area behind the wheel wells where the trays are is recessed slightly.
I got mine from AutoAnything.com.
Let me know if you need additional pictures.
Thank You very much - I see now. I was just about to go out into the garage and pop the back hatch.
Has anyone put the 40230 inside of a 4runner with the double deck? I personally have DD but don't ever expect to use it and i find the 40228 which doesn't cover the entire cargo area when the deck is down to be annoyingly short. I'd rather cover the entire area...even if it means that lifting the deck is not practical without removing the mat.
seltzernator
