Pranav
So after last time's fun, I decided to take a crack at it again.
My best was a 15.22 @ 87.87mph. I also got a 2.17 60' and 0.0024 reaction time while running in a bracket
On my 2nd bracket run, I had to brake before the finish to avoid breaking out, although looking at the times leading up to the 1/4, I probably could've broken into the 15.1s.
After winning the bracket I tried manually shifting during the late night time trials to see if I could break into the 15.1s, but I just couldn't do it. I'd either bounce off the rev limiter by mistake, or just mess up in general. However, on my 2nd to last run of the night I set my best 60' (2.16), but slowed down just enough between the 330' and 660' marks to end up with a 15.24.
http://home.mindspring.com/~pranavyp2/1117DR.htm
It was a stock '03 Limited 2wd v8, with just a drop-in K&N filter. Temps ranged from the high 50s to high 40s. The only change made from the last event was the removal of the spare tire.
