ive decided to drain and fill to try and get most of the old oil out. so would i do this about 3 times lets say. my local sams club has dexron III fluid for 19bux for 12qrts. could i run this stuff to most of the old stuff out and then possibly put good oil maybe on the last fill. or should i use the good stuff the entire process? any recommendations? the stuff at sams club is a store brand atf but its for dexron III/mercon. would this be ok. i think our 4runner calls for dexron II so im pretty sure this is ok for it. i know some use amsoil the entire process. is this overkill if you plan on draining it out anyways. ???
