Drive Belt Tensioner Issue
cabowally
Guys:
My 03 4R drive belt tensioner had a case of the squeaks so I pulled the belt and gave it a wiggle. Enough play to suggest the pulley bearing was bad. Ordered a new pulley from NAPA (wrong pulley size, thanks very much, but the bearing was the same). Pulled the old pulley today and discovered that the bearing was completely seized. Put the new bearing into the old pulley and put it back on only to discover that the seized bearing had just kept spinning on the aluminum post of the tensioner assembly and worn it down enough that it the assembly and pulley need replacing.
FYI: don’t assume that the pulley bearing is the only issue on a problem belt tensioner. Off to order the whole freaking thing…
Hope this helps someone.
Guys:
Any pics?
You just helped me!!!
Im doing a 90k service soon, and was debating whether or not i should replace the drive belt tensioners....after reading your posts, i most DEF. WILL!
Thanks!
