Drive shaft vibration
bumg56
I have a 1998 4Runner 2WD, V-6 with 200,000 miles. I have replaced the u-joints three times in the last two years and am still having vibration issues. I have checked the splines and there are no issues there. I marked everything before removing and disassembling it so it went back in the same way it came out and apart. It starts out as a fine vibration at speeds above 65mph and gets worse as speed increases from there. This is the only truck I have ever had issues like this with, I have replaced many u-joints in the past on other trucks with no repeat issues. My only thought is maybe a balance problem?
Any help would be appreciated.
Check your rear wheel bearings and tranny mount, I replaced them on my truck and that fixed the vibration on my truck. '87 4runner with 207,000 miles.
I replaced the wheel bearings a year ago when a seal went south without the truck. Trans mount is solid, as are the engine mounts, differential was overhauled when I did the wheel bearings.
Thinking I am going to take the drive shaft to an axle shop and have the balance checked and another set of u-joints.
I appreciate the input, I was trying to get a second opinion and maybe see if there are some common issues.
Ok, no ones asked the important question. Is your suspension stock or have you lifted it on any way ?
Suspension is stock, shocks front and rear, sway bar bushings front and rear, steering gear less than a year ago and tires only have 10,000 miles and balance on them has been checked.
Ok, next question. Have you ever pulled the drive shaft totally apart?
If you have and put it back together and where off by just one spline, you'll get vibes.
At fourwd1;
It is a one piece drive shaft, (2WD not 4WD) so it does not come apart like the 4WD shaft does.
I appreciate all the help from you folks, looks like it may be headed to a drive line shop to check for balance. This was my first thought, but I wanted to know first if there were any common issues with the 2WD drive shafts.
2001ATL
