Driver door question...
t4newb
Ok I'm going to explain this to the best of my ability. I have a '98 toyota 4runner limited, and my lock button will lock/unlock all my doors, but my drivers side door. My friend and I took the door apart and after some searching on the net found the actuator that controls the driver door(we even went to the junk yard and got one out of an older model, but the actuator was different. Then we went to a Toyota dealer and they wanted $108 for one...). We took it all out. We took the actuator apart, and hooked the motor up to a 9 volt battery and the motor was good(everything else was fine about the actuator). So my question is where should I be looking now for my problem?
why not swap with one from the rear doors? Some yota models actually had a safety (fire issue) recall due to a relay that controlled the actuator sticking. I've had aftermarket actuators ($15 each) that stick - take them apart and they work for another few weeks.
Gonzaga Lobos
