The part numbers are spot on, ordered them (~$24 with shipping) and was an easy install.
You don't need the screws, the existing ones (hidden) work just fine.
how did you install it on the driver side? what do you mean the existing screws are "hidden"?
As far as hitting it with your head, I built a grab handle out of paracord and mounted it there. Just modified the existing caps to allow for the handle and it looks almost factory. I will post up some pictures if anyone is interested.
Sure, here you go. I saw it done on another 4runner forum and I really like how it looked and it works just as well as any other handle. I do hit my head on it sometimes, especially if I'm wearing a hat but it isn't a nuisance at all and if I took the time to adjust it, it probably wouldn't be an issue. However, I don't use it as often as I thought I would when I made it.
That looks Awesome!!!
You said you modified the caps? Do you have any pics of how you did it?
I don't actually. That took longer than make the actual handle. I basically pulled them off and cut them up and built a base of the shape and then used bondo to fill everything in. after it was dry I went back and carefully sanded it smooth and sprayed it with some gray primer that ended up matching the color pretty well. If you didn't want to go through all that trouble you could just cut a groove into them that will allow you to pull on the handle without them getting popped off.
That paracord grab handle looks great! I saw 4wheelparts had ones that go around the front headrests for the rear seat passengers. The damn plug on the driver side grab handle keeps popping out (2nd time now and I lost the plug), maybe I'm just too fat.Sure, here you go. I saw it done on another 4runner forum and I really like how it looked and it works just as well as any other handle. I do hit my head on it sometimes, especially if I'm wearing a hat but it isn't a nuisance at all and if I took the time to adjust it, it probably wouldn't be an issue. However, I don't use it as often as I thought I would when I made it.
Part numbers for the handle and accessories are as follows. These are for the stone (gray) color. The difference in part number for other colors ar the -B0.
74603-60010-B0......grip subassembly.....23.54
74617-60050-B0......plug......................2.88
74617-60040-B0......plug......................2.88
93381-26030...........screw (4).............. .48 ea. I don't think you need these.
Do a search on the forum. Many people have done this mod. I got the part numbers from those posts and kept them as I plan to do the mod soon.
Anyone know if the parts dept of the dealers have driver side grab handles available Why did they not put them on, there seems to be a place for them.
B
