Driver's window "Auto" doesnt work anymore!
zerowkul98
For whatever reason it wont go up or down completely with the "Auto" feature like it used to.
Anyone ever have this prob?
Window will go up and down if the switch is held, like the other 3 windows.
Did you disconnect the battery? If so, you'll have to reinitialize the window, the rear tailgate window, and the sunroof.
The flashing is a first for me, but as mentioned having to reinitialize is common after a battery disconnect. Press and hold down the switch to roll the window down, and once its all the way down continue holding for five to ten seconds longer. Do the same when you roll it up. Same process applies to the sunroof and rear window as well.
Apologies, i paniced.
Yeah, i had to take the battery out in order to get the front "parking light" bulb out of the lens housing due to them burning out.
I should have done a search in the forum first, but thanks for the help.
The rear window needs that same process?
