DRL mod disabled auto power window and headlight time-out
wasc007
O.K. I installed the DRL relay on my 2006 4-runner SR5. The DRL function worked as advertised. However, I noticed that:
1. My auto power window on the driver side no longer worked
2. The factory headlight timeout also was disabled (in case you left the lights on and forgot about it).
Does anyone have any additional information on this issue? It's a hard trade-off to have DRL and no auto-power window.
Thanks! and
Happy New Year!
Originally posted by RX900 - Wait it out. Play with the window for a few times. It should "relearn" how to use the auto driver's window. I didn't know the auto off headlamps are included with it but it should go back to normal.
You are right!!! RX900
The system did "rel-earn" everything. It took about 30 minutes (maybe less, but I was driving it around).
It's pretty scary how changing a mechanical relay changes the parameters to the ECU and the system re-learns itself.
thank you very much!
I did not disconnect the battery terminal. Maybe I should have as a safe thing but I didn't. However, to get to the fuse box and install the relay, I did have to unplug all the connectors to the fusebox so that maybe equivalent to disconnecting the power to the ECU?
sorry about the duplicate, I did try to delete it as I realized I posted in the wrong area under accesory for sale.
