drum brakes warped ?
kennyb3030
been having my rear end vibration, i think it could be the drum breaks in the rear are warped. the 4r will vibrate as i go down the road, but there is no vibration when i get on the brakes, is this possible with warped drum brakes?
Like I already said. Swap them front to back. If the vibration goes to the steering wheel then you know for sure.
If the rears are warped then you can test by using parking break at driving speed (35) should do it. Of course keep button in and slowly pull on the brake handle. If warped you should feel it in the handle and hear the uneaven friction.
Like everyone else said, tires.
Rear drums will vibrate pretty aggressively with pedal application (or slight lifting of emergency brake handle).
had my tires rotated at lunch and nothing has changed. just tried the e brake and it only clicks 2 times when i pull it up, and it only comes up about 1/3 of the way. so now i know for sure that my e brake is locked up ! going to have the e brake and rear breaks checked out next week
