teotwaki
Senior Member
There is a kit sold for FJs and I worked a deal on it, providing feedback as to the differences with 4Runners. The fenderwell mounting and battery position are a bit different for our 4Runners. The kit has all cables premade. Kit from Dirty Parts in Culver City, CA
Optima yellowtop battery mounted on fenderwell using battery tray made to fit, leveled by poly spacers underneath. Leaving room for the hood gas strut was critical.
Control solenoid (200A continuous) mounted to battery tray. Battery control is essentialy manual: Secondary battery in parallel only when ignition switch is on (battery isolated when ignition is off), secondary battery isolated from primary, or secondary battery can be forced in even if primary is dead (self jump start mode). See control switch pix below.
Control switch in cab. Dual color LED: Green when ignition switch on, red if battery is forced across primary battery.
Wiring to control switch through firewall. Main battery lead next to it.
Connection of secondary battery cable to primary battery
