Dual smart usb to replace cla - pt976-03201
AZrunner11
I recently discovered that Toyota makes a fantastic part to add new technology to the future classic OG Trail Edition, being the OEM dual smart USB to replace the 12V cigar lighter adapter. Most importantly, I was able to confirm it is plug and play for the 2012 Toyota 4Runner which most likely indicates it will work on all years of the 5th Generation Toyota 4Runner. The most difficult decision was deciding if it should replace the front console, inside the glove box, or the rear cargo hatch.
That's all we get? No install instructions?
I put mine in the center console storage to replace the cig lighter port.
That part number requires tapping into factory wires that is referenced in that link while this part number is 100% plug and play directly into the factory harness for the 12v adapter.
Sorry no instructions yet. I merely tested that the harness would be plug and play last night in my 12 T4R by access the rear hatch cigar lighter plug.
This weekend, I will get the tool to remove the Cigar Lighter Adapter and look into adding this to the glovebox CLA or under the dash. I have added a picture to include the harness on this particular part.
If this is used in the dash to replace the single USB, what happens with Carplay if you connect 2 apples devices? (2 iphones, iphone and ipad, etc)
This replaces the 12v cigarette lighter adapter and not the single USB in newer 4Runners. In my 4Runner my USB linked to the radio system is in the glove compartment and I have an old school "line in" beside my 12v power supply.
Instructions: http://toyotaparts.sparkstoyota.com/install/PT976-03201-4run.pdf
No special tool needed. Just a small screw driver.
Personally I wouldn't bother doing this. There are plenty of very low profile 12V to dual USB adapters available that do a nice job. There's always the possibility you might want the 12V socket for example a GRMS radio that needs 12V.
Hoping someone might see this old post...
I'm thinking of switching the cargo area 12v to USB outlets with PT976-03201, but I have the 3-prong outlet hooked up with an Anytime 400W wiring harness. Does anyone know if there are any issues using the two parts in conjunction? I'm not much of an electrician, but I'm wondering if the 400w harness would feed too much power to the standard USB outlets. I don't have any appliances or tools that use the older 12v plugs.
TIA
Wow
All my stuff has been USB-C for like a Decade, now. This is SO behind-the-times (and also less-than-useful for me, but maybe others will like / use it).
