E-brake light stays on when E-brake disengaged
pencil_&_paper
The red e-brake light stays on when disengaged. I'm going to take a look at it right now, and was hoping for any useful hints or suggestions.
I have electrical contact cleaner and lithium grease, and I'm going hunting...
Hey thanks!
The reservoir was full, so I unplugged the electrical connection, sprayed some electrical cleaner on both the male and female sides and that fixed the problem.
I had just used engine shampoo, so some water must have entered the connector.
Where is the electical connection that you mention?
I'd like a quick and easy fix for the brake light on problem. Where is the electrical connection you mention? Thanks for your help!
quick and easy fix to your warning light problem.....
black-color-duct-tape.ashx
First, check the brake fluid level and top off if necessary.
Next, there is a connector on the side of the brake master cylinder.
