E-break light sensor? Anyone have this problem?
coltonbaxter31
Okay so this started about a month ago.. When i do a role on or kind of get a quick start and get to 3,000 rpm + and then completely let off the gas it does this. The E-break light just turns on real quick and then goes away. The E-break is not on at all so I'm guessing it's just a bad sensor. Anyone else have this problem? It doesn't effect the 4Runner at all other than the light
https://vimeo.com/119404770
Low brake fluid. You either need new pads/rotors/shoes/drums, or you've got a leak somewhere.
CHECK THE BRAKES BEFORE ADDING FLUID.
I've seen two people just add fluid, then have one or more of their rotors break. And I mean BREAK. They lost the front brakes because the rotor wasn't attached to the wheel anymore.
ghengiskhan
