Did a little analysis. The assumptions are that the setup cost is $375 and that the average prices are as shown below, per AAA website, yesterday.
There is some good info and some bad info in here. Ive been running and tuning 400+whp cars on e85 for over 5 years now. All my friends run e85 in there high HP cars.
1. There is a loss of 10-20% in MPG if running straight e85. At WOT the air/fuel misture will need 30% more fuel than gasoline to get a good air/fuel mix. So if running pure e85, if your ECU cant compensate up too 30% fuel/air change than you will run lean at WOT and start to eat up valves. Yes it may take a long time since we dont run 4runners at WOT that much but on my talon it could eat up a valve or piston in a madder of a few WOT runs. So if switching over too pure e85 you want to have something to control the fuel/air mixture.
2. You dont make power just switching too e85. I have dyno tested this and so has lots of other people. If you car was running real low octane causing detonation and your timing was being retarted then yes you will gain power but that would happen only if running too low of octane for the car to begin with. You only gain power when you add timing, compression or boost to the motor and e85 allows lots of all those things. It never detonates/knocks and you can actually lose power from adding too much timing since it never detonates.
3. You dont need to upgrade fuel lines as long as the car is made past 1989. Thats when they started adding 10% ethonal to gasoline and asked all car manufactures to make stock rubber lines e85 safe.
To run e85 safe
1. You need some time of fuel management and a WBo2 so you can watch your AFR's and make sure your running safe.
2. If running boost you will need to upgrade fuel injectors and fuel pump to handle the added fuel at WOT. Usually around 30% more fuel at WOT and 20-30% more fuel at cruise and mid fuel trims.
3. You will need to pull injectors every 10k miles to have them cleaned. E85 has some type of addative that gums up the fuel injector tips. It can get so bad that the injector can fail and in our high HP cars its usually very bad at WOT on the track. You can either clean them or run gasoline sometimes to get the goo out but you will need to retune too do that.
If anyone has questions running e85 send me a PM. I dont have knowledge running it on our motors but I have extensive knowledge tuning and running it on other vehicles making lots of power. My talon was running 32psi on an holset HX35, 12.0 AFR (lean for that much boost) and over 24* timing with zero detonation on a stock Mitsubishi 4 cylinder block. E85 is awesome stuff!
I am interested in converting to flexfuel on my 2003 V8 4Runner. Naturally aspirated. What is the best thread for this? Has anyone done it?
IanB is right. on natural aspirated engine there is no gains. on a turbo is where it shines. horse power records have been broken cause of the E85. Rotary engine also benefits from it since its burns cleaner and cooler.
super charged?
anyone tried this?:
APE Flex Fuel
In vague general theory, you cold put injectors on with about 25 - 30% more flow and let the stock ECU figure out the rest - the narrowband O2 sensor will find stochiometric regardless of fuel, all it's looking at is left over oxygen.
I've never seen that before but looks pretty slick. Surprisingly, installation doesn't look too bad either except for how to figure out the fuel line connection.
Definitely has potential but you would have to be the guinea pig and try it first. We do not have the ability to advance timing so there's not as much of a power gain compared to other vehicles.
Not very true with the 5vz, but many/most other models that is reasonably true...It states that the factory ECU will run more timing advance with the APE.
-Charlie
The 5vz ECU completely ignores the knock sensor below ~3k rpm and runs fixed (conservative) timing in that area. This is why the supercharged guys lave low RPM pinging issues. No idea *why* but, there you go.Would you elaborate, please? TY![]()
