Ebay clear corners-Can you bake them apart?
crackiswack
Does anyone know if the Ebay clear corners like these
can be baked apart or if they are held together with epoxy/glue. I want to pull them apart and paint the inside black
They'll melt.
The clear corners themselves or the sealant? Is the plastic not the same as the headlight plastic? I've baked apart enough headlights to know what temps/time to use to not melt the plastic. Basically I just need to know if the clear corners use the same butyl rubber sealant to hold the two halves together like the headlight portion or if they use an epoxy or silicone sealant, which do not melt
There was a guy one here who tried to do it, I forget who, but he melted the lenses before the glue. Ended up buying new ones.
