ebay Wheel Spacers
The hub ring looks very thin on the ebay ones for some reason.
Compare them closely to SpiderTrax or All Pro and you will start to see differences.
Also, depending on what you are going for, 1.50" is sticking out pretty far...1.25" might fit better?
Can't we keep this forum MORE family friendly?
This is a 4runner forum and not a 18+ site. We have minors as low as 16.
The ones in the link are hub centric. I was trying to determine my options, if any, aside from Spidertrax and Allpro. Would 1.25 get the tire flush with the fender? Is not being able to use the ET nuts make these unsafe?
probably the avatar.
* I have All Pro 1.25" on OEM 5 Stars w/265 Duratracs on a 98 Limited and they poke out a tiny bit past the fat flares.
1.00" spacers would be perfect for me. I currently do not us ET Lugs, but would feel better about myself if I did.
If there's a problem why don't you come out an say it? :vader:
My avatar is nothing that any 16 year old kid couldn't find on his own. Not to mention there is no nudity in it, she has a shirt on, and there's no nips. Turn on MTV and you'll see more than my avatar shows.
Not having ET lugs are not the end of the world. A lot of people run them on the front just to help grab more threads. I wouldn't say that not running them is a bad thing, just recommended. If you buy some from All Pro's site, they'll even suggest it before you check out. You can also look into Synergy wheel spacers, and you can get them from Polyperformance (ET's don't work with them either though).
Thanks for the info. I will check out the others you mentioned. If I have more plausible choices, I will have a much better chance of getting some used.
Crookedcat
