Ebay Wheels Spacer Kit Question!
Email em and find out if they are lug centric or hub centric. Im guessing they are lug, u want hub centric, all pro off road has them the cheapest I have found. Let us know, if they are hub centric Im in 4 a set too :)
email em and find out if they are lug centric or hub centric. Im guessing they are lug, u want hub centric, all pro off road has them the cheapest i have found. Let us know, if they are hub centric im in 4 a set too :)
x2!!!!
I Will email them right now....im a newb guys..whats the difference does it make between those two?
Edit: Just researched...Need Hub Centric
Lug centric hubs mean the weight rests on your lugs, not the hub, hub centric hubs means the weight is centered on your hub.
I would not go cheaper on eBay. Just spend the extra $50 and go with All Pro or Spider. You'll be much happier in the long run (besides - All Pro are like ~ $100).
BTW - the Toyota spacers on eBay are lug centric. This does not matter if you run after market wheels, but if you stay stock then you should get the hub-centric ones.
(besides - All Pro are like ~ $100). BTW - the Toyota spacers on eBay are lug centric. This does not matter if you run after market wheels said:
Good to know! I think all pros are $79 a pair, and he quoted me $20 on shipping for a full set, so like $180 shipped for a full set, still cheaper then spidertrax, and not blue lol
Depends on where your rubbing, when you put the adapters on you will rub more somewhere else.
Its rubbing on the CALs near the spring...do you guys think I can wait few days for the all pro and save $40? I just dont want anything to happen to the tires will all that rubbing
So I gave All Pro a call and turns out the shop is only hour away from me...so went and picked up 1.5 HC spacers for $150...install was super easy but had to do little bit of trimming....will post pics today
Sweet! looking forward to pics!
