Eclipse 6620AVN with everything
cmyrunner
I have an Eclipse 6620 Full nav/ gps and dvd player with all the accessories. full 7" screen Can be grounded to play dvds while vehicle is in motion. Has the bluefusion which allows you to use your steering wheel mounted controls for BT wireless audio streaming, bluetooth, back up cam, i pod adapter, Sirius radio adapter and system is plug and play with the 05-11 tacoma and most toyotas. spent well over 1800 new with all the options but will let go for 800 obo. pics to come soon
AVN6620
GENERAL
Power output 50W 4 (MAX)
Power supply 13.2V DC (11—16V)
Dimensions (W H D) 7 4 6-1/2 (180 100 165mm)
Weight 7.0lbs (3.2kg)
DISPLAY
Display 7 wide (16:9), low-glare panel
Resolution 280,800 dots (400 234 3)
Screen aspect ratio 4 types
FM TUNER
Frequency range 87.75 — 107.9MHz (200kHz step)
Usable sensitivity 12dBf (98.1MHz)
AM TUNER
Frequency range 530 — 1.710kHz (10kHz step)
Usable sensitivity 22V
CD SECTION
Frequency response 20 — 20,000Hz ±1dB
Total harmonic distortion 0.01% (0dB 1kHz)
MS SECTION
Frequency response —
Total harmonic distortion —
EQUALIZER SECTION
Equalizer 63Hz — 16kHz (25 points) ±10dB
HDD SECTION
Operating temperature range —
Storage temperature range —
iPod® is a trademark of Apple Inc., registered in the U.S. and other countries.
DVD Navigation
7 wide display
Touch control
approx. 8.76 million POIs
City map
Traffic Information
DVD Video
Dual zone operation
Multiple search modes
Split screen displays in navigation
Map scale from 150 feet to 250 miles
Time zone (4 areas)
Voice guidance in English, French and Spanish
50W 4
Circle Surround II
FM/AM
Advanced 24-bit DAC
7-band PEQ
Crossover
Listening Position Selector
5V preamp output
AV output for rear monitor
AV input
ESN (Key CD security)
interested.
AVN6620
GENERAL
DISPLAY
FM TUNER
AM TUNER
CD SECTION
MS SECTION
EQUALIZER SECTION
HDD SECTION
DVD Navigation
7 wide display
Touch control
City map
Traffic Information
DVD Video
Dual zone operation
Time zone (4 areas)
50W 4
Circle Surround II
FM/AM
Advanced 24-bit DAC
7-band PEQ
Crossover
5V preamp output
AV input
having a difficult time loading pics. they are available per request via email or text. I have all the parts and even an extra wiring harness.
seltzernator
