prodigy2k7
Start the engine and allow it to reach operating temperature. Note any unusual sounds. Timing chain replacement is straightforward and provided the instructions in the service manual were followed, the engine should operate normally. Shut off the engine and check the fluid levels and inspect for leaks. Start the engine once more and set the ignition timing per the underhood emission decal. EFI-equipped trucks are set to 5-degrees BTDC with the EFI check connector shorted. Carburated trucks should be set to 0-degrees BTDC with the vacuum lines disconnected from the vacuum advance unit.
Where is this "EFI check connector" and how do you "short" it?
Does short mean disconnected?
