EFI Cleaning? 2004 V8
rsimpson
Recently had my 4Runner in for 55k service (oil change) and the service manager recommended that they do an EFI cleaning and wanted $160 for it. They said "there is some carbon build-up and your throttle is sticking."
I purchased the truck with 45k miles on it and will assume it has never been done before, but is it really necessary that I do it? Is $160 the going rate for this?
I do notice there is some slight hesitation at low speed, low rpms and I'm averaging about 16.5 mpg (a lot of city driving). I also notice that the ignition has to turn over couple more times to fire up compared to when I got it a few months ago...
By the way, my dealer also wanted $70 to replace the cabin air filter:eek: -- Hence my hesitation to move forward with any additional service that isnt standard procedure...
Your opinions are appreciated!
Ryan
Ask for an itemized invoice of the work to be done if you think he is bs-ing. I have always wondered myself what exactly the EFI cleaning is all about.
Ryan
I hope you DIY'd the cabin air filter and told them to take a hike!:moon:
Get an itemized explanation of what the EFI cleaning involves. You may need a throttle body cleaning but some places don't do that. They hookup a machine and do an injector cleaning that doesn't do the throttle body. Others just do the throttle body.
Make sure you know what your paying for...
:cheers:
How does the vehicle run? At your mileage I would do the TB cleaning myself, and pour a bottle of Techron cleaner in the gas tank. Also do the home depot cabin filter mod yourself. And stay away from a stealer that charges $70 for cabin filter replacement.
Yeah, when I worked at a Toyota dealer their idea of efi cleaning was taking the intake hose off spayin some carb cleaner in the throttle body and giving it a quick scrub with a toothbrush! I say keep yer money get a haynes service manual or similar for $12 and do it your self!
$70 for cabin filter? that is plain robbery. Takes about 5 minutes to pull it out, clean it and put back in (procedure outlined in manual). If its really bad, replace it
i totally agree with these guys, tell the service manager to take a hike. clean the filter & TB yourself , pour a bottle of techron in.
The butterfly valve can get cruddy and stick closed or not close all the way, it's a good maintenance item. But never use carb cleaner, use throttle-body cleaner, or you might damage some expensive sensors. I've run injectors over 200k without a cleaning, but they apparently do gum up on some cars. Most fuels have injector cleaner in them these days.
