Rust_Bucket
Truck: 1990 Toyota 4runner, v6 auto 4x4
So my truck decided to die on the side of the road yesterday. The motor would crank over but would not start. After doing a bunch of trouble shooting I noticed that the 15A fuse for EFI was fried. I put a new fuse in, then pulled it right out and it was okay. Then I put the fuse back in (using a 20A), and turned the ingition to try and start. No go. Sure enough the EFI fuse was blown again. Tried once more and had the same result. Ended up having to get towed home. So there is a short somewhere, that I'm quite possitive about. I'm just wondering what wiring I should check with knowing the details above? I was thinking ignition to starter wiring? Could the starter short out internally? Any suggestions? Thanks guys
