Coastal616
Really feeling that color. Nice ride!
Thanks! I totally love it, it almost looks black in the shade, then olive/gray in the sun.
Looks good man! I really like what you've done with it so far! :trophy:
Thanks, Main reason for Camburg, uniballs instead of bushings, price, and boxed arms.
I actually got the wrong fenders, they are for 97-99 tacomas, apparently they make a 96-97 fender too, I think the early ones would have fit better and possibly used the stock corner lights.
Tundra front diff with a 9" ring gear, I had it narrowed to fit.
I don't know how I didn't see this before. This here ^^ is the shit. Looking for more information on this. How much did you have to shorten the diff? Did you use Tundra axles? RCVs axles?
Badass build dude, Looking forward to what you decide on for the rear and if you keep the outboard setup.
Could you sneak a picture of how you have the alignment cams tacked? Ive heard of people doing that but never seen how it looks, do you take the bolt to the big washer or the washer to the frame? Or am I in left field and totally wrong?
Nathan
Haha, ya nobody really seems to grasp the awesome of this mod when I get around to it. You can see the OEM aluminum piece that was just off in one pic. My friend made me the steel bolt on piece that holds the seals and bearing and being steel it will be easy to weld to to mount the diff.
I havent decided on spindles yet, I could run the stock stuff, with RCV shafts and probably be fine, I did buy F350 Unit bearing to build a beefy custom spindle with locking hubs, or I could go with Tundra spindles modified and use stock tundra shafts which are pretty beefy, but the only problem is tundras are 5 lug.
Lots of options, just depends on how much time and money I want to invest. Once its done, I will have a bomb proof IFS front end that I don't have to worry about.
I really like this thing. I think some hydro bumps in the rear might help. These runners seem real limited on compression travel in the rear. I have been looking at mine and think that is the best bet.
So you used the center diff from a 07 and up Tundra?
