CBR_GUY_IA
ELECTRICAL
EL010-07
REVISED
Title:
WIRELESS TRANSMITTER &
PROGRAMMING GUIDE
Models:
'90 - '08 Applicable Toyota
November 9, 2007
TSB REVISION NOTICE :
^ November 10, 2007: A TSB reference has been updated in the Programming column of the Application Chart.
Previous versions of this TSB should be discarded.
TSB UPDATE NOTICE :The information contained in this TSB supersedes TSB No. EL008-02. TSB No. EL008-02 is now obsolete and should be discarded.
Introduction
Difficulties during Remote Keyless Entry (RKE) Transmitter Programming can arise due to confusion between Toyota Factory Wireless systems and Toyota Port/Dealer installed systems. This bulletin will assist in identifying the system/correct remote transmitters for each vehicle, and provide the location of the most accurate programming procedure for each system.
Applicable Vehicles
^ 1990 - 2008 model year applicable Toyota vehicles.
Warranty Information
System Identification
The Application Chart contains all of the necessary information to correctly identify the type of system installed, and where to go to get programming procedures for each vehicle.
Should a vehicle having both VIP and Factory systems available (as identified in the Application Chart) be brought in without any remotes (or one non-working remote), use the following tips to help determine which type of wireless system (O.E. or PIO/DIO) the vehicle has.
^ Look at the Trim Level of the vehicle. Higher-grade vehicles will tend to have O.E. systems, while entry-grade vehicles will tend to have VIR For example, the 2001 Camry XLE has Factory WRKE, but the LE and CE grades have VIR
^ Look for a "Status Monitor" with a glass breakage sensor and an LED externally installed into the dashboard or on the center console. Most VIP systems will have this.
^ Locate the ECU (refer to the applicable vehicle VIP Manual installation instructions for location). Once located, refer to the part label.
^ Attempt to perform the factory wireless programming procedure to get a response from the vehicle. Select the "confirmation mode" and see if any "Lock/Unlock" response is received, if so, the vehicle has a factory system.
Application Chart
Wireless Transmitter Identification
EL010-07
REVISED
Title:
PROGRAMMING GUIDE
Models:
November 9, 2007
Introduction
Applicable Vehicles
Application Chart
