Electric windows / Mirrors -Fuse ?
Surf89
I cant seem to isolate the fuse for the electric window/mitrors in yhe engine bay. could someone tell me where it is ? Thanks...
The fuse for the windows and mirrors should be on the driver side kick panel. I know your model is overseas, but I would think the fuses would be in the same place.
I cannot tell you which one off the top of my head but look in one of your owners manuals, there is a diagram in there that tells you which fuse is what.
Power windows use a circuit breaker, not a fuse.
It's located in the upper right corner of the fuse box behind the drivers side kickpanel.
You might consider pulling the door panel and check if the switches are getting any power at the circuit. It's also worth investigating the wiring harnesses in the doors, especially at the flex points(see pic).
regards
allcarhistory
