Electrical fault
ashtheflash
Hi
The EFI fuse is burning up every time. Now I've changed the relay, ecu, checked the wiring, with or w/o A/C, to no avail. The car runs for a while, then the fuse just pops.
Anyone with ideas much appreciated.
Check all your wiring. There was a time where my O2 sensor wire rubbed raw on a heat shield, causing the EFI fuse to blow every time I went over a bump.
