Electrical hookup for tow
zamboknee
How do I attach/rig an electrical hookup for towing to my 2002 SR5?
I might be getting a pop-up camper and need to be able to hook up brake lights, etc.
You should have a trailer harness attached to your hitch if you got one from factory. Otherwise you'll have to install your own. Buy a universal harness from auto parts store and tap into your brake light wires.
Sent from my SM-N910V using Tapatalk
check to see if you had the module first, I had the 4 pin connector and everything but with no power output. Pulled apart the side plastic in the back and found a complete, new hookup set that just needed plugged in. the plug and play is nice
AndiGarage
