greatape
Senior Member
Finally figured this thing out...after the ABS pump/ecu was replaced...it was reading codes for a fault in the unit.
After replacement, the issue came back again.
Have to hand it to the awesome tech at Findlay Toyota in Flagstaff, Arizona who took the time to drive around with me for an hour until we replicated the intermittent issue.
Turns out there are 2 brake switches on the brake pedal; one just turns the brake lights on when the pedal is depressed. The other is essentially a brake pedal position sensor switch, which reads to the ABS, VSC, A-Track and Traction Control ECUs...basically every bell and whistle that's attached for traction control of any kind.
This switch is located vertically behind the brake pedal itself. Apparently, a loose pin fit, when the wiring vibrated (and gravity, I suppose) caused all sorts of intermittent ground faults; essentially causing the dash to light up like a Land Rover.
Field fix was to zip tie the lower wiring so that it was tight; not allowing the pins to fall with vibration or gravity. A new wiring harness was installed, and no more issues.
Odd placement for something that could cause so many issues. I may make a guard for it, just so it doesn't get kicked or knocked.
Hope this helps!
-H-
I need to travel up to your dealership! Yesterday, I was cleaning up the rig and noticed the rear spoiler had shifted loose apparently for some time and actually has rub into the hatchback down past the primer in the paint...
