Electronic Rear Hatch if Power Out?
DennisW
Hi,
Anyone have any idea how to open the rear hatch in case of a power or other failure?
There wasn't anything in the manual and I could not find any release levers or anything.
Just wondering...
Thanks,
Dennis.
probably can't...You can still get in the drivers door so i guess the next step would be to restore power. You can't get locked in the rear so need for an emergency handle.
On the tailgate, there is a small 3"x3" panel that pops out, behind which is a sheet of plastic, behind which is the manual release for the tailgate.
I can somewhat access a solenoid looking thingy but couldn't find anything resembling a manual release... Do I need to cut out all the plastic?
Unfortunately, the box I built in back covers that hatch, so I'll have to figure out an access workaround...
Thanks!
Dennis.
Hi,
There wasn't anything in the manual . . .
My manual (Owner's Manual?) must be different than yours. Page 595 has illustrations along with the following text: If you cannot operate back door opener
Remove the cover on the back door trim.
Tear the plastic film. Remove the cover.
Pull the lever.
Thanks!
Dennis.
As Froggy pointed out, the latch is covered, leading me to believe that Toyota only added the access panel after some American lawyer started acting as if the world was ending because "trapped" people couldn't get out of the back door.
That being said, a thin wire rope crimped to the latch on one end and a t-handle on the other end might solve your particular problem.
Thanks for the idea! A bit of tan paracord secured up the door might work for my emergency 1-time only use and may be a bit more clean.
I will have to check out my manual to see how I missed it...
Dennis.
I know this thread is old, but did you figure out your window issue? I can't roll mine down. Not sure where the fuses are at for the read window. Someone said it could be the motor itself, which are very hard to find.
I have to replace a brake light and can't get the tailgate down. I will try the "emergency" latch mentioned in this thread. But, would really like to get my window working again.
I cant post yet, but I was wondering if anyone knew a way to set the rear window parameters in tech stream? My cable in the back hatch broke so I put the window up all the way and glued the sliders to the rail. but now my wiper wont active because the Computer thinks the window is still down.
