Elocker question
kolelt
Does the elocker it self has a breather like the axle housing does ? And is the breather same style. I'm trying to make sure I'm not missing anything.
It does have a breather but it's a tiny thing
Gotch ya. That's what I figured. It does not seem to be the same pressure valve as the axle housing. Seems to be just a simple tube.
I want to extend my rear diff breather and elocker breather. And I'm wondering if I need to use the Toyota pressure valve DIFF ?
Want to put the breathers either in the gas tank area. Or inside the car.
I remember my breather on my 2000 seemed to be missing some stuff. I didn't realize this until I got a replacement rear axle ( the entire thing from a 97) which had a little cone shaped check valve. I think it tucked away in the frame somewhere. Found this
41507-35040 - Toyota Parts Deal
The elocker breather is different then axle housing breather though correct ? When we pulled the elocker axle out. There was a small valve breather on the axle. And a long rubber line on the elocker. I just want to make sure I didn't lose anything or something was lost.
Yes, they are different. The e-locker breather does not have a valve.
Mike Sargent
