Emergency Brakes
qballjr13
I recently did the back brakes on my 04 Sport. Now I can hear what sounds like the emergency brake shoes dragging inside the rotor. Also the e-brake is no longer holding the vehicle if I am in drive. Does anyone know how to adjust to the emergeny brakes / cable?
Thanks all
Back in Turkey, I have adjusted e-brake cables on Opel's, but never done it on a 4runner and I am a brand new owner..lol
However, there should be a small adjusting sprocket somewhere on the "Rear" brake assembly thru a lug note hole or something. You should be able to do the adjustment with a screwdriver maybe. It should feel like a gearing system...
Free bump for you though. All I said above are from past experiences. I could very well be out of wack as well. Good Luck...
Re: Re: Emergency Brakes
drmorbius said:
There should be a reference to this in the manual. Have you tried backing up and tapping the brake repeatedly? Still it sounds like something other than an adjustment is needed. I would go back in and have a look. Anyway good luck.
I havent tried going backwards and hitting the e-brake. The rest of pads seem to have seated themselves very well. Taking it all apart again would be a hassle that I am not looking forward to.
I will look for the adjustment screw or something along those lines.
Re: Re: Re: Emergency Brakes
Sorry you even saw this I removed it 5 minutes later as it totally doesn't apply in this situation. There are slots in the backing plate to access the adjusters. Crawl under and look with a flashlight and you should be able to find them.
Re: Re: Re: Re: Emergency Brakes
No problem :)
Thanks for the help guys, I will climb under and check it out.
