Engine and trans mount upgrades?
TopElement
What upgrades are available and what have you used?
As I'm now working on making the suspension and drivetrain as smooth and slop-free as possible, it's time to keep the engine and trans movement to a minimum.
Ordered "Bomb Proof" engine mounts from LROR, but need a trans mount upgrade too. On the LROR site, the beefy trans mount is smaller for the wimpy engines, and the 3.0 only seems to have an OEM available.
Any input would be appreciated.
I went with the factory(OEM Toyota) drive train mounts, and they have been fine for the last 40k. I also replaced all the rear control arm and lateral arm bushings with urethane which has probably helped elongate the life of the factory motor and trans mounts. The old rear suspension bushings had the diff and axle assembly slopping all over the place which could not have been easy on the other mounts in the system.
regards
