Engine coolant temperature sensor
Herculean T4R
Where is engine coolant temperature sensor that sends signal to cluster gauge located in the engine bay?
I know the location of the sensor that sends info to the ECU but can't locate the second sensor.
A pic will be helpful.
Thanks!
back right of the engine up against the firewall. Most likely will need to remove the Heater core hoses for easier access I changed mine it was "that" hard. I took off my hood also, Either a 10 or 12 mm deep socket fit over the sensor and out she came.
seltzernator
