Engine loud metallic engine rattle @1800 rpm after sitting in traffic
protist
I have a 1999 Limited V6 4x4 automatic with 122,000 miles.
Over the last year I have had an engine noise that has progressively gotten worse. After I sit in traffic for over 5-10 minutes depending on the temperature outside, hotter=faster, I get a bad engine rattle when accelerating at 1800-2000rpm, particularly uphill, like getting on a onramp to get on the interstate.
If I go on the interstate for a while and come off the interstate then the noise is gone, but in city traffic the noise only goes away only if I go over 2000 rpm for 15-30 seconds. If I start out driving on the interstate for over 15 minutes then I never seem to get the noise.
The noise goes up and down with the accelerator. I find that I am unable to reproduce the noise when parked in neutral and revving to 1800-2000 rpm, but I figure it is engine related because it is accelerator dependent.
Any ideas?
I'd like to give this post a bump. I have a 99 SR5 4x4 and have a very similar situation to what you are describing.
Someone mentioned it could be the lifters.. I frankly have no idea.
Any leads would be a big help.
Cheers,
Andrew
My valves rattle when under heavy loads and sometimes after setting in traffic! i was told thats a common problem with 3.4! But mine is pushing 307k on the clock
Hi,
Check the exhaust header brackets that attach to the manifold flange.
Both mine were cracked and rusted through at the flange
