engine oil cooler
1998 2WD Auto 3RZ does not
you can kill it on a 5VZ
Toyota Oil Cooler Removal Kit 3.0L 3VZ-E & 3.4L 5VZ-FE - Kit-1076
Hey guys, hope all is well.
If you replace the oil cooler, does the new one not have the hose? All I can see is the flower looking piece, no hoses around it. Pretty sure there is a leak in this spot.
I doubt if it comes with the hose.
Usually there is nothing wrong with the cooler that a bit of cleaning won't cure.
There's not much to them but there is an oring or two that seals it to the block.
Is it leaking oil or coolant?
If it's coolant, it might be one of the hoses.
PRWhite
