Question??? Do I need to swap over the original engine oil cooler on my 3VZE to a new(used) 70k mile 3VZE truck engine? The truck engine I believe is a '91 Taco 2wd. My T4R is a '93 4wd. I've pretty much gone through everything else maint related and I don't want to smoke this engine by not keeping the temps down. I did notice the oil pressures were lower after the swap when the engine is warmed up. Which I am assuming is because the oil temp is higher E.G. lower viscosity.
