Engine Oil Cooler?
snunez1999
I just noticed that my 99' 4Runner 3.4/v6 is leaking oil from oil cooler. I didn't know it even had one. I looked it up on repair manual and it says its an engine oil cooler. Do I need to replace part or just gasket or seal?
Thanks for the help!
Not sure how much this helps but... I just had my '95 3.0L in the shop and the mechanic said my engine oil cooler was slightly leaking as well. It was his opinion that only the gasket needed to be replaced, but that's where it was leaking from. So if it's leaking from the gasket you might be able to get away with just changing that... much easier.
