Engine saga continues
I may have got to the bottom of this one.
You folks are likely to all get a good laugh at this one, and what it appears to have ended up being that caused all these problems. I am a novice, I admit it, and clearly went about this effort all wrong...too many parts and lots of wasted time and money...only for a simple fix to be the issue.
What I did since the last post:
1) gave up on the professional help theory. Dealer, private shops, didn't matter; lots of people with ideas and willing to take more money, no results. Surprisingly, many of the shops I went to were very much into "throw parts at it" much like I was doing myself, rather than good diagnostics. Anyway, onto the rest of the story.
2) I heeded advice here and ordered OEM plugs and wires. In the meantime I started to chase down fuel pressure as a possible cause. The fuel pressure regulator didn't seem to be operating as it should, based on vacuum tests (I didn't have equipment to properly test pressure) so I ordered one of these as well.
3) Then I undertook to have a look at the crank and cam position sensors. Seemed OK.
4) To change the fuel pressure regulator, found that whole intake had to come off, so did that. While in there took off the injectors and sent them to Witchunter for service ($120...great service BTW). They came back with a report showing injectors were more or less OK, a bit out of balance, but all cleaned and ready to go.
5) Put everything back together, new intake gaskets, installed new bango bolt with a port on it for fuel testing. Along the way also ordered budget version of an OBDII tester....so many choices couldn't figure out which one to buy but ended up with "Launch C Reader V".
6) Get it all back together, try to start, no start...dead as a doornail.
7) Try new OBDII tester. Follow instructions, it shows up with code indicating bad Crank Position Sensor. So I get a new CPS from the dealer, install. Still dead, no start, code still there.
8) Call mechanic (back to the pros) they suggest they have seen cam sensor fault show up as crank sensor fault on some cars, suggest change of cam sensor. More parts. Change cam sensor with new OEM part. Still no start.
Same code still there re Crank sensor. Talk to parts shop about whether crank sensor may be bad. No co-operation.
9) I start to chase wiring to crank position sensor. Wires ping out with good continuity (from computer to connector). Upon real close inspection, HOWEVER, I notice that the factory plastic wiring surround has a break in it in one spot (near where a small plastic bracket is taped that holds the wire in place). Close inspection (I had to pull back the cracked plastic covering), reveals a damaged wire inside. It appears that the whole affair had rubbed up again the alternator belt at some point and rubbed away the wire cover. Wire is damaged, corroded badly. As I cut it away I see it is corroded back into the wire about 1.5 inches from where the damage to the sheath of the wire had occurred, some broken strands etc.
9) So I fab a small piece of wire and cut it back till I reach good wire, splice in a new piece. Lots of tape and a few tie wraps to hold it all in place. Connect everything back up.
10) Truck starts right up, idle smooth, running like a swiss (OK Japanese) watch.
So far no return of the original "hot soak" hesitation problem. So my theory is that this wire was the key problem all along. Perhaps it was making partial connection and as it heated up, its character would change and its ability to conduct the signal required to the computer was impaired. When I disturbed the wire by my initial inspection of the crank sensor it could conduct no more, or was doing so on and off, and that is what caused the no start condition until it was repaired. Any thoughts on my theory of temp affecting this wire?
In any event, I am hoping I actually got to the bottom of this.
BTW I went back to the dealer to show them the fix and they don't believe it. The theory they have (now!!...first time this has been mentioned) is that my real problem was likely with the intake gaskets, and that when I changed these to get to the fuel pressure regulator, I may have inadvertently fixed my problem. I am not buying it, I think the wire was the issue. But at least it appears to be fixed....and now I have lots of new parts on the truck!!!
Glad to hear you're up and running with no problems!
Still sounds like a mystery to me though since too many things were done at the same time. Keep us up to date though :)
Thanks for the good wishes 004Gunner, but I am back with the same trouble!!! I am embarrassed to be back at you guys with this persistent issue. I was so excited to have found that bad wire going to the crank sensor, but I guess that wasn't it.
I have never been so frustrated with a vehicle. The only other thing I have done was I hooked up a fuel pressure gauge with a long hose into the truck so I could watch it while driving and while the hesitation happens. It is rock solid at 45 psi...drops maybe 1-2 psi on really hard acceleration. Rock solid when the hesitation happens as well.
I am at a complete loss as to what to do next. Anybody want to buy a nice 1999 SR5, 110K miles? Nice shape, looks great, lots of new parts, runs like a piece of crap...
Could it be the transmission...remember, it only gives an issue after being warm and sitting for like 10-15 minutes? Sure doesn't seem like a tranny issue, but I am obviously not the best at diagnosis, so WTF do-I-know...
Bill
Bill
Still waiting for the OEM plugs and wires to arrive?
I would love to see live data from a scanner when the problem occurs. Anyone performing diagnostics would have this ability. I would still hold out hope for the proper plugs and wires
OEM wires and plugs were put in at the same time injectors etc were done. It may have made a slight difference in that it runs a bit smoother overall, but it has done nothing for the key problem I am having, unfortunately.
I agree that live data would be helpful. You would think something would show up there. One of the two shops I was at had me drive around with some kind of a memory stick plugged into the OBDII connector. The problem happened mulitple times while this was plugged in and when I asked them about it after they removed it all they said was "all the data was fine". It may be that a proper Toyota scan tool diagnostic scanner would be better able to take down more parameters and information.
I have an appointment at yet another shop with lots of Toyota experience, so unless I come up with some other ideas on my own or from this board I think that is what I will do.
One more update - and a QUESTION
Well I brought the truck to yet another shop, not a dealer but a well recommended shop that apparently has lots of Toyota experience. They were helpful (sort of) but still no fix. What was learned:
1) they did some tests to confirm it is apparently not head gasket related
2) they had the proper Toyota scan tools etc and said "fuel trims" look out of whack (but apparently not so far as to throw a code)
3) they suggested changing the forward cat sensor, the so-called "fuel air ratio sensor" but they were not totally sure, so they did not want to step out and actually do that (knowing all that has already been done, including this sensor)
So their suggestion was "go to the dealer"...they suggested they have a ready parts supply and can throw parts at it to get to a fix.
They didn't take any money from me and apparently worked on the car for a couple of hours trying to diagnose, so I guess that is positive, but I am still without a clear solution here.
So I guess I try another dealer.
QUESTION:
In my 4Runner saga, I didn't own the truck when the sensors were changed. I don't even have the bill for that work (but it is clear they are new and were changed). I wonder if the wrong part was put in, ie non-cali sensor might have been put in, ie a regular O2 sensor, put in rather than the heated fuel/air ration sensor. I found a thread on this site where this happened to somebody...so that might be worth chasing.
Anybody know how to tell the difference between the proper air/fuel ratio sensor versus a regular O2 sensor by looking at it?
May be on to something
Per my earlier post, I just pulled the front sensor (remember this is the one installed by the prior owner before I bought it).
Just like described in the thread I append below...it looks like some grease monkey shaved off the plastic on the connector to make the wrong sensor fit.
http://www.toyota-4runner.org/3rd-gen-t4rs/71294-need-some-help-2.html
The part is definately denso, but the numbers on it are as follows:
1) up on the top near the wires the numbers are 42140 followed by 08L04 right under that
2) then on the body stamped into are the numbers 2571
Who knows what Toyota this is supposed to be for, but it appears I had the wrong sensor in there. Working theory till I get the right one is that maybe this is indeed an air/fuel ratio sensor...just not the right one.
That is why it runs OK some of the time (won't throw a code) and runs like crap other times.
This seems like a good lead....
stay tuned
billsheila -
I believe you sent me a PM on this issue a few days ago. After reading this detailed post it sounds like your issues run deeper than mine.
As far as that possible incorrect part goes, I would think that you could contact the dealer parts dept with the numbers and they could tell you the specs on it.
I know its frusterating trying to track these type of issues down. I had an older Cherokee that had a cold start issue and never figured it out. Tried the usual (fuel pump, filter, sensors, etc) to no avail.
I would still recommend disassembling the IACV valve and cleaning. Its pretty easy and aside from $8 worth of gaskets, its free.
Re the IACV, I may indeed end up doing this. I did sort of clean it when I went after the Throttle Body cleaning, I just didn't take it all apart. This latest shop that got me onto checking my air/fuel ratio sensor were pretty insistent that they thought my IAC valve was working fine.
I am hoping the correct Denso A/F sensor part shows up today and my plan is to put that in and go from there. Honestly, if this doesn't do it, I can do what you suggest re the IACV and after that, I am replacing parts that are already replaced, at least relative to the entire fuel system having been gone over + some ignition parts.
I am hopeful I am onto something with this air/fuel sensor given the experience of this prior post and the advice of this experienced shop -- ie both pointing in that direction.
Hoping for a blissfil evening with a well running and non-sputtering 4Runner...
Purrrrrfectly
Well that was it.
The bozo (not me, the other bozo) who shaved down the connector on the wrong denso air fuel sensor in a classic "I'll make it fit" move -- was the cuprit.
By this point I am pretty adept at re-creating this problem that I have been having and ....I can't make it do it!! It seems to run better right off the line and by all accounts seems to operating normally. Yahoo!
I guess I can be a ready supply of spare parts now for the rest of you guys...if anyone needs anything from all that I replaced that were all good parts, as it turned out, just let me know.
I have used but otherwise apparently good:
crank sensor
cam sensor
Other stuff was tossed along the way. THANKS for listening to the saga, HOUSE episode...whatever you want to call it.
Now I am on to getting a few other things sorted on the truck and hopefully some mods!!
Thanks for sharing your experience even with the potential embarrassment you spoke of earlier in the post. valuable experience that you have saved us from going through.
freddygino
